| Гость_Admin_* |
31.12.2004, 2:35
All about patches for Strong SRT 6xx5 only here (manuals, troubles, download links).
Soft upload is here - http://upl.frocus.net/index.php?lng=en&p=4 Manual - http://www.frocus.net/main.php?lng=en&...tatii&pag=7 |
| Гость__* |
4.1.2005, 13:35
Hi, please where can I found the upload zone? I don't understand russian language?
thank's |
| Гость_Admin_* |
4.1.2005, 13:48
DOWNLOADS SECTION: http://upl.frocus.net
| Гость__* |
16.1.2005, 3:55
Hello,
I saw in the creenshot the strong 6xx5 patch replaces the design of the interface. Can I change the color or make the menu items rounded not square? |
| Гость__* |
17.1.2005, 19:18
Please tell me if I can keep the original design of the menus after I apply the patch.
thanks. |
17.1.2005, 20:49
Местный активист ![]() ![]() ![]() ![]() ![]() Группа: Главные администраторы Сообщений: 19676 Регистрация: 11.9.2004 Пользователь №: 11 Спасибо сказали: 10409 раз Вставить ник Частич. цитирование |
(Anonymous) Please tell me if I can keep the original design of the menus after I apply the patch.
thanks. No, you can't change OSD. |
17.1.2005, 20:56
All about patched firmware that emulate Viaccess 2.3, NagraVision, Seca, Irdeto and Conax on receiver Strong SRT SRT 6125 (6155, 6355)
(unfinished article based on original "loading steps.txt"). Introduction. Strong SRT 6125 (6155) it is a receiver for reception of free (FTA) satellite channels. But were found so-called crackers which have changed the initial soft (firmware) sewed up in a receiver, that it could decode the channels crypted in Viaccess 2.3, NagraVision, Seca, Conax and Irdeto (without a card of conditional access, without a user's payment). It was required to update in time only keys for these cryptings. To download the emulator (patch) in a receiver will be necessary: 1. receiver Strong SRT 6125 (6155, 6355) - 1 piece. 2. computer - 1 piece. 3. serial cable - 1 piece. 4. programmes: BootLoader.exe ApplicationLoader.exe PatchLoader.exe 5. patches and firmwares: srt61x5fta.urt (or srt6355ci.urt for a Strong 6355) keys.bin patch.bin All soft you can find into: "srt 6xxx loaders.zip", "srt 61x5 patch.zip", "srt 61x5 patch [9-12-04].zip" and other packages. TO PATCH AN VIRGIN SRT6xxx RECEIVER YOU MUST FOLLOW THIS STEPS: 1. Connect the PC and the SRT6xxx using a null-modem serial cable. Follow the route [ Menu Key -> Installation -> (Enter your securuty code, by default 0000) -> System Set-Up -> System Information ] such that the firmware version is shown. 2. Unplug the receiver, press CH-DWN and keep it until you plug in again the receiver. 3. Run BootLoader and perform CONNECT , this will replace the original boot. 4. Perform again step 2 and run ApplicationLoader, load the application (6xxx.urt) and upload the application. 5. Perform again step 2 and run PatchLoader , load the patch (*patch*.bin) and upload the patch. 6. Perform again step 2 and run PatchLoader, load the keys (keys.bin) and upload the keys table. 7. Start the receiver normally. 8. The online key tool will be used to view the keys present or the user will be able to add or delete his own key. a) Follow the route [ Menu Key -> Installation -> (Enter your securuty code, by default 0000) -> System Set-Up -> System Information ] such that the firmware version is shown. 1. KEY_4 2. KEY_2 3. KEY_2 3. KEY_5 . So the sequence "4225" will invoke the WeakSoft Editor for further use. c) Follow the instructions given at the bottom of the menu to proceed further. Frocus (december, 13 2004) Updated 11.01.2005 |
| Гость__* |
18.1.2005, 17:27
Thanks Frocus.
I presume the OSD design was changed because of the limited space on the receiver but if thats not the case can you guys leave the default design on? Also a bit off-topic, is there a similar patch for 'worldsat discovery 520' receiver? |
18.1.2005, 19:59
(Anonymous) Thanks Frocus.
I presume the OSD design was changed because of the limited space on the receiver but if thats not the case can you guys leave the default design on? You can ask developers about this trouble: www.prosat.ro |
| Гость_ed_* |
7.2.2005, 2:44
Hello,
How can i back to the original SRT6125 software? :?: greetings ed |
| Текстовая версия | Сейчас: 9.10.2026, 23:06 |
